Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
A linha de laptops MacBook Pro da Apple foi concebido para os usuários avançados e profissionais. A linha MacBook Pro inclui o MacBook Pro 13" Monobloco, MacBook Pro 15", MacBook Pro 15" Monobloco, MacBook Pro 17" e o MacBook Pro 17" Monobloco.
17526 Perguntas Visualizar todos
MacBook Pro 2010 Mid 15" 1333Mhz 8G RAM Upgrade?
Hi all,
I had a 2nd MacBook Pro 2010 Mid 15" with i7, 4G Ram (It is a 1333Mhz, and using 1 Bank, so I still one bank RAM slot is empty right now).
I had search Google before, and look like this model work with 1066MHz only, but I am not too sure. Since new on this.
I want to buy other 4G Ram then install it to the empty slot.. But now, all 4G Ram is 1333Mhz, can't find the 1066MHz Ram anymore on 1st Market ...
Do anyone using this model who success install two 1333MHz 4G ram running on it?
I am using OS X 10.9.5 and OS X 10.10.2 with dual boot on it..
Thank you.
Best Regards,
Jimmy Chan
My web site
My blog
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 1
Comentários:
ABCellars,
Thank you. I had using my old T420s's 1333MHz 4G install on my MacBook Pro 15" 2010 Mid.
It work with two 1333MHz 8GB now (Two different brand RAM together)
Thank you.
por
Adicionar um comentário
Kit de pontas universal para chave
112 bits for every fix.
Upgrade Your Toolbox
1 Resposta
Solução escolhida
It has been known to work most of the time, sometimes not. However, putting faster memory sticks in won't buy you better performance. You are limited by the clock speed of the front side bus and memory controller. You are restricted by the design the engineers originally intended the limits to be.
Match the existing stick of RAM and you should be fine.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jimmy Chan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 463
