Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3531 Perguntas Visualizar todos
No sound after speaker replacement
Hi, I followed this guide. I have problem with my earpiece speaker after i reassemble my screen, it doesn't work and i should talk with the speaker, why it happen and what should i do???
Tanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi Ali,
1st and foremost, why did you need to change your ear speaker? What happened? Was the old ear speaker working at all before?
2nd, to get you started, and if you were not hearing any sound to begin with, may be the ear speaker mesh is dirty. Poke 2~3 holes in the middle of the mesh using a fine needle. Do not insert it more than ~1 mm. If you start hearing better, then you need to replace the mesh, not the ear speaker (or leave it like this now that it's working). Try this and let me know.
3rd, it could be that the part you used is defective, or you received the wrong part. Where did you get it from? Does it look exactly like the ear piece you removed?
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi, Thank you for your reply,
I don't replace my earpiece speaker, i have problem with my screen and after i fixed it, i reassembled it and i did't do any thing with my earpiece speaker, but after i reassemble it doesn't work, now i thing maybe it has problem and replace with new one but still it doesn't work., PLEASE, PLEASE HELP ME, to understand the problem.
por
"but after i reassemble it doesn't work, now i thing maybe it has problem and replace with new one but still it doesn't work." => Ali, what did you replace again? A new screen or a new ear speaker? Or a new cable that holds the Front_Camera + Mic + Ear_Speaker + Proxy_&_Light_Sensors??
por
Hello,
I had the same problem, after change the broken screen the earpiece never worked again.
I'm wondering if I damaged the earpiece or something else. I had very carefull with the flex cable, don't think is broken. Tried to assemble and reassemble everything few times and still doens't work.
Should I order a new earpiece or there's something else I should do?
"Poke 2~3 holes in the middle of the mesh using a fine needle" Din't understand what you want to say with this, can you please send me some photos or explain me better?
Thanks in advance
Pontuação 0
Adicionar a sua resposta
Ali Sakhtianchi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 184
