Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
iBook G3 won't boot, can't install a system
Hello,
I got an old iBook G3 model A1007 900 MHz recently, but I never managed to make it works. I tried to instal an OS on it but it won't let me do it.. When I turn it on, plugged or not, the iBook make the noise of the start then a black screen appears and shows me a little icon with a "?" in the middle of the screen.
I have no idea how to reinstall something on it as nothing is working.
I can send you screenshot if needed.
Thanks alot
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
The question mark means that it can't find a valid operating system. First do you know if it has a hard drive? Are you trying to install from the original system installation disk or something else (please tell us what you are trying to use.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Hi,
Yes it does has an hard drive as when I received it from my friend it was with an old OS all in chinese, but I haven't got an orignial system installation disk with it. I haven't try to use anything on it, I just wanted to use it :(.
por
Pre-Installed MacOS: 9.2.2 & X 10.2.4 Maximum MacOS: X 10.4.11
Here's the info on your machine: http://www.everymac.com/systems/apple/ib...
por
Where can I find the iso to burn it on a disk ? And how to make the iBook boot from this disk after ?
por
Adicionar a sua resposta
Fanny será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 263
