Changing the oil-pan internal filter?
In the sump pan or oil pan at the base of the engine , exists an internal filter that needs changing or replacing. How do I go about this ?
Esta é uma boa pergunta?
Donald Walcott, check this video. Just skip installing the Fumoto Valve.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 931
2 comentários
I am not sure about an internal oil filter. I checked the service manual as well as the oil pan itself and do not see anything you are referring to. Where did you get the information from? What year is your Corolla and what engine size is it?
por oldturkey03
I have a 2008 corolla but its not an internal one. Its on the front side of the oil pan. It's a bit of a reach, I could only get it by going under the front.
por Goulithum
