Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Pergunta encerrada
iPhone 5s won't turn on after Camera replacement.
I followed the iFixit camera replacement guide and after I finished it the phone wouldn't turn on. So I changed the camera back to the original. And it still wouldn't turn on. I double checked the steps. And still no luck. Can someone please help me?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Maybe you forgot to turn the device off. Disconnect the battery and power up again.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your help. I tried what you said with still no luck. I read through the article again and it said if you put the wrong screw in the wrong hole it can cause severe damage to the logic board causing boot disfunction. That's most likely what I've done. After that I made sure the right screws were in there place. And disconnected and reconnected the battery. With trouble still.
por
Have you tried starting it up without the camera plugged in?
else if you have mixed up the screws on the shield which covers the lcd/digitiser/front camera, you could have damaged the traces
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 490
