Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36386 Perguntas Visualizar todos
Does the iPhone factory reset after screen replacement
First I didn't think the iPhone would factory reset, but I saw a video where et looked like it did. Can anyone tell me, does the iPhone factory reset after screen replacement or any other sort of repair?
Esta é uma boa pergunta?
Pontuação 5
2 comentários
My iPhone dropped, but I have a screen protector so I thought it would be fine, but the cracks went underneath the protector and my actual phone screen cracked. So are iPhone protectors even worth getting?
por
A military-grade maximum protection phone case is worth getting if you’re worried about that screen cracking which is always a big concern for me personally. I purchased the most rugged Otter Box I could find. It doesn’t have a screen cover which in my opinion is worth the viewing experience.
por
Adicionar um comentário
1 resposta
Solução escolhida
No. The iPhone memory contents will still be there after the screen repair. Even in iPhones that the battery is completely disconnected, the iPhone keeps all its data content intact.
Esta resposta foi útil?
Pontuação 8
3 comentários:
if i get a lcd phone repair will it reset?
por
No
If they are resetting it it means they are going inside the phone
but if its screen repair nothing happens they are not opening inside
por
1.IPhone never does factory restore on its own.
2.iPhone do not require factory restore after repair
IPhone may require factory restore if repair was done incorrectly
por
Adicionar a sua resposta
Rimti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 41
Duração total: 51,735
