Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Pergunta encerrada
I replaced my MacBook screen and now won't start up right
My MacBook Pro, after putting it back together, won't start up properly.
The screen stays black, no chimes or noises, and the white power light fades out and doesn't come back on. Also, After a minute the keyboard backlight will come on and eventually turn off as if going to sleep or something.
I'm wondering if I need to just replace the video cable or there is some real issue here.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Help us help you. The more complete the description of your problem is (some background or history about why you had to replace the display - dropped, liquid damage) the more assistance we can provide, and, the sooner we can provide it..
por
Well, no liquid damage or phsical damage to the screen at all. Was just a simple take wires and screen from one top shell to another.
por
Liquid damage to the logic board (components) could be an issue with not booting. Sometimes corrosion damage takes time to build up enough to cause failures. So if the machine was liquid damaged that information is Germain to finding a solution.
por
Adicionar um comentário
1 resposta
Solução escolhida
99.044% of the time a reassembly issue is a connector that is incorrect (loose or misaligned). Go over all your connections(ors) again looking for a ribbon cable that is not fully inserted and locked, or a connector that is not "snapped" in.
Some of these latter machines will not boot without a fully charged battery, or, mains power and a ~20% charged battery.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I'll give that a shot. I've been having a suspicion that is also the issue.
por
I accept this because, once I opened it up and re-ran the wire everything worked. The machine as working properly the whole time, but the non-video through off my perception of what is going on.
Plus took it to Apple and confirmed.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 811
