Ir para o conteúdo principal
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Perguntas Visualizar todos
Why wont my screen work when I turn it on?
I have an early 2006 iMac 17 inch intel base. It runs and runs great as long as I have i hooked up to another screen. can this be repaired by me and @ what cost?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
since you can see the picture on an exteral monitor, it's not a graphics processor problem.
is the screen totally blank or can you see a faint image ?
sometimes the backlight inverter or the backlight itself dies - but then you should see a faint image on the screen (especially when you use a flashlight and hold it close to the screen).
Esta resposta foi útil?
Pontuação 1
Is it a grey screen? Just stays black? Or just is blue? If its black it means there is probably a problem with the connector cable going to the screen or logic board.
If its blue or grey it means its stuck starting up in which case it a problem with your harddrive or logic board.
Pontuação 0
Adicionar a sua resposta
joe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 825
