What adhesive to Fasten Frame to Shell?
The loose hinge problem turns out (in my case) to be a frame that apparently separated from the aluminum shell of the Display Assembly. Is there an adhesive that you sell, or that you recommend, to fasten it back in place, so that the "loose hinge" doesn't break the glass covering the LCD (again)?
Esta é uma boa pergunta?
