Wifi and Rear Camera not woking after screen replacement
After replacing my screen on my iPhone 6 I noticed the rear camera would not load (also the flashlight does not work). So I took it back apart and took the camera off and then put it back on and now the wifi is not working either. I have tried hard resetting and resetting network settings. I am on iOS 8.1 and jailbroken if that helps.
Esta é uma boa pergunta?
Is the device registering panic.plist or panic.ips in the dianostics & usage menu?
por Josh
no its not. but now the phone is randomly shutting off if i lock it and dont touch it for a few minutes. and it wont restart without doing a hard reset. any help would be greatly appreciated asap. Ive restored to the latest firmware and that didn't fix anything
por AndrewHaskins1
Very carefully inspect the resistors around the battery connector for damage.
After Inspect resistors by the LCD, digitizer & sensor cable connectors, your looking to see if any were physically damaged by a tool while working. You may have to remove the black plastic static sticker to see visisble damage. let me know your results, take your time inspecting. Some of the resistors are so small they look like bits of dust. This way we can rule out any obvious damage.
por Josh
theres no way i could've damaged it because each time i reconnected the battery it went right back in. Now one of the times i was putting everything back together I powered it one before putting on the retaining plate for the lcd and digitizer connectors, and there was lines running up and down the screen. So i tried to turn it off but it would not power down so I just disconnected the battery while it was still on. Could that have caused this problem?
por AndrewHaskins1
Josh what would the blow resistors look like? Same problem, I'm down to solve the issue though have soldering skills
por Matt K
