Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Perguntas Visualizar todos
My iPad won't charge. What should I do?
My iPad won't charge. What should I do? I tried using different iPad Chargers and Cables but it doesn't do anything. I also tried plugging it onto the PC but it doesn't react as well.
I tried turning it off, then plugging the charger in and like what its supposed to do, it turns on! I don't know what to do now that I'm reaching 10% battery. Turned off wifi and turned the brightness on the lowest. I hope i get an answer before it dies off.
Esta é uma boa pergunta?
Pontuação 15
1 comentário
I need more battery!! I need 2000&
por
Adicionar um comentário
4 respostas
Solução escolhida
If you are using a known good (original) cable and a known good wall charger, and still it doesn'tt charge properly, then there are many other reasons why your iPad is not charging, and you need to open it up to find out why. You need to follow the path of current to see where it is broken:
1/ The charging dock is defective and not passing the current like it should;
2/ The charging dock is fine but due to a fall, it moved and needs to be reseated on the board;
3/ The path is partially broken on the logic board which is malfunctioning. You will need the help of a trained technician to troubleshoot and repair this one;
4/ The battery bank is not holding a charge like it should. One good way to tell is if one or more of the batteries is swollen. But it could be defective and not swollen.
Not to sound discouraging, but to open the iPad and test all those, you may need a new dock connector and a new battery, and still may have not solved the issue. Plus you might break the front panel during disassembly.
If you feel up to it financially, and have the time to do it, let us know and we can guide you through the needed steps to minimize unneeded expenses and maximize chances of locating the fault. Or you can take it to a reputed repair shop and have it diagnosed first.
You can read through this guide to see what you will be up to if you decide to try the repair yourself.
Esta resposta foi útil?
Pontuação 7
I've been having this problem too, but mine died and just has an endless loop! I NEED HELP
Pontuação 1
== Escape to your own dream island! Join as my Beach Buddy and play #FVTropicEscape for free.
https://5rfu.app.link/CLQ9YRBcbD'''bold text''' ==
Pontuação 0
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
Pontuação 0
Adicionar a sua resposta
vincentdlsvds será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Duração total: 27,139
