Pular para o conteúdo principal
Can I upgrade the iPhone 6 Plus from 64 GB storage to 128 GB
Is it possible to switch out the 64 GB flash drive in my iPhone 6 Plus and put in the 128 GB drive instead? Was this possible in older iPhone models?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 9
Comentários:
well. not suggest to do that, as for my iPhone, i have change the screen, and after changed, the screen doesn't work well now, even though i changed the screen provided by apple. So i think it's better to not change everything in an iPhone.
To get enough storage, there are many other tips, you can refer to them: http://t.cn/R54aH53
por
yes you can heres a store in the USA that can http://www.rewatechnology.com/solution/s...
por
https://goo.gl/28zKJQ
Some video shows how this is done .
por
Adicionar um comentário
6 Soluções
Solução escolhida
There is no flash drive just soldered flash memory chips.
Sadly, you'll need to swap out the complete logic board which is quite expensive! Best to sell and buy a new unit with the larger storage.
UPDATE
While the flash chip can be replaced it does take a bit of skill, availability of the chip and the needed programer. This it's not a DIY project for a good 90% of us.
Even still as Tom pointed out there are risks if the upgrade will be stable and its already known some actions don't work correctly.
Given the market its still better to buy a new phone! If you must trade it in or even sell it your self to recover a good part of the costs of a new phone.
Esta resposta foi útil?
Pontuação 12
You can resolder a bigger chip onto it, then you'd have to do some factory level programming to initialize the chip and write config data into it, which i don't know if it is possible.
UPDATE:
It is possible now, some Chinese repair shops are offering this upgrade:
http://www.askci.com/news/chanye/2015/10...
Based on customer feedback, if all serial number/MAC addresses are rewritten properly, the phone works with no problems. However Activation Lock seems non-functional, you can successfully enable find my iPhone on it, locate it remotely, but after a DFU forced restore, the phone can just be activated again without having to reenter your apple ID.
And whether new updates or activation server changes will improve or destroy the phones are not known.
Pontuação 7
Comentários:
So that article is telling me that I can infact do it myself. I mean with Verizon, if I put in a new chip with a different meid and serial number, i can just register a different phone, no problem. My warranty is up so I don't need that information anymore. Am I wrong to think I can do this myself? I am a pretty handy engineer.
por
Go ahead and do it. Sounds like you are smart enough to figure it out.
por
Mostrar mais 3 comentários
Yes you can. But the only way is change the flash ic inside logic board and need to reprogram the serial no. same as your existing flash ic serial no.
Pontuação 3
Comentários:
So.......no.
por
In Texas we call this the stuff that drops out of a horse's back side.
por
It is possible now and some people are already offering this service.
por
Where? I'd pay to have it done
por
The only way to upgrade the internal storage is to swap in a logic board from the same model with a larger storage module. As other posters have mentioned, it's possible to unsolder the storage chip from the logic board and solder in a larger one from the same model/generation - if you can find a larger module and do the solder/replacement without wrecking the logic board altogether, or can find someone you can trust to do the work.
This has been true for every model/generation of the iPhone.
However, if the goal is simply to get more mobile storage attached to the iPhone you already have, there are external options for adding extra storage:
  1. Mophie has made a line of charger cases called "Space Packs": A protective case with a secondary battery, plus 8-64 GB of built-in flash storage, depending on the model. They've recently had models available for the 5/5S/SE, for the 6/6S and for the 6+/6S+; I've seen used units for 4/4S listed on eBay and my local Craigslist. SanDisk has a similar case called the iXpand, with storage amounts up to 128GB - but only for the iPhone 6/6S. The basic iXpand has no expansion battery, but there's a clip-on battery pack available as an add-on.
  2. There are Chinese vendors on eBay who do plastic cases with slots for microSD cards, similar to those used for extra storage in some Android phones. The iPhone models I've seen have a slot that's supposed to accept up to a 256GB card. While the Mophie cases have a secondary battery, the Chinese cases have a Qi wireless charger receiver built in, like the Qi wireless charging system built into the iPhone 8/8+/X. That way, you can lay your phone down on a Qi charger (either a common generic one, or the one that Apple will release this winter) to recharge it. Use the keywords "memory", "expansion" "wireless", "charger" and your cellphone model and you should find something.
  3. What I use with my iPhone 6S is a third option: A Lightning-to-USB dongle with built-in flash storage. It has a Lightning connector at one end and a USB-A connector at the other; you can connect it to your phone/iPad or your computer as a thumb drive, and you can use the entire dongle as a super short recharging cable. The flash drive appears as a standard finder volume on a computer, just like any other thumb drive. On an iPhone, you access the external storage through a management app from the manufacturer, which allows you to move files between internal and external storage, or to view/play/edit files stored on the external drive. SanDisk sells a version under the iXpand name, at sizes from 16-256GB. Lexar sells a version called JumpDrive c20i or c25i, in sizes from 16-128GB. A consumer note: Crucial/Micron, Lexar's parent company, has recently sold the Lexar division to a new owner, and Lexar flash devices are going cheap right now. I find that movies stored on the Lexar drive play as smoothly in Lexar's management app as they do in Apple's TV app.
Pontuação 1
It totally is. I’m starting to think jessbethany has some affiliation with Apple.
Pontuação 0
Change the disk with larger and transfer the device details to new disk .
Pontuação 0
Adicionar a sua resposta
Brett Denaro será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 58
Últimos 30 dias: 325
Todo: 50,144
