Ir para o conteúdo principal
Released in late 2012, the Asus X55C is a 15-inch laptop with a screen resolution of 1366x768. It has an Intel processor inside and uses Intel's integrated graphics.
16 Perguntas Visualizar todos
Laptop Screen shows Pink/Green Horizontal Lines at the bottom.
I have no idea how did this happen.
I left it on while I was sleeping and when I woke up in the morning, it already has these pink lines (when on white background) or green lines (when on black background).
Esta é uma boa pergunta?
Pontuação 20
8 comentários
My Macbook pro just did this problem this morning ,but after coming home from school I took the risk of slapping the back of the screen near where the little apple sign is and when I did the pink and green lines disappeared.
por
It may come back. I recommend you ask a new question https://www.ifixit.com/Answers/Ask
por
@Prime Noscope67 your solution worked for me
por
It's the indication that your system is corrupted
por
I don't believe your system is corrupted. It's more than likely a loose wire joining the computer parts to the screen. I've seen it go away , temporarily, when the strip next to the side of the screen is pressed. But for a more permanent fix you may need to dismantle the plastic round the screen to get at the loose connection.
por
Exibir mais 3 comentários
Adicionar um comentário
18 respostas
Solução escolhida
Aju krishna, could be the LCD panel or the GPU. Connect an external monitor. If that show a good picture you know it is most likely your LCD panel that needs replacing. If the external monitor is showing the same issues, you have having problems with the GPU on the logic board and will have to at least disassemble your laptop to inspect. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
Pergunta mais útil
place your thumbs on the top corners of the screen and your fingers on the laptop cover. Gradually apply pressure with your thumbs until the colour is correct. This happens to my laptop every summer.
Pontuação 20
22 comentários:
"place your thumbs.......", I laughed when I read that but then I tried it. It didn't work with thumbs at top of screen but then I made my way down the sides of the screen and when I got to the top of the pink area and pressed with my thumbs the screen magically returned to normal. So I conclude that a lot of these problems are definitely caused by loose connector cables between the laptop and the LCD screen.
por
dude it worked you saved my life i love you (no homo)
por
OMG.. even I laughed at this solution but it worked ... Thank you so much..
por
Can somebody show how to do it via some video and provide the link here
por
Thank you!! The line was still present after I pressed on it but after a few secs it returned to normal.
por
Exibir mais 17 comentários
It's the connector cable from the laptop to the LCD screen that isn't connected properly.
If you take the screen surround off and then reconnect the screen cable and make sure it is fastened secure, this will get rid of the pink and/or green lines.
Pontuação 7
4 comentários:
how exactly??
por
i have only one green vertical line on my right side of the screen laptop
how? the pressing of top corners didnt worked for me :(
por
Same here like cenyom, except it's a pink line... How to fix it??
por
It's working, Thank you for the solution :) LOL...
por
The video was unavailable .
If someone knows something that can be done , ls let me know . The pink lines are getting larger ,thanks
Pontuação 2
Thank you
Pontuação 1
1 comentário:
i hate asus laptop so many problems
por
This has occurred with my laptop too...for 2 consecutive years; however, since I live in a part of the world where seasons change dramatically from exceedingly hot summers to exceedingly cold winters, I noticed that the morning pink and green lines only appear in the winter when temperatures go down to sub freezing. So, simple remedy: I now wrap my laptop in a blanket, or put it in an insulated bag before I go to bed, then, abracadabra, when I open it up in the morning, there are no green/pink horizontal lines!!!
Pontuação 1
2 comentários:
WTH??? Come to think of it it was really hot today and in the evening it rained and the temp went down and just then the screen went all pink and green lines... And I seriously thought i messed something up??/ But does temp really affect this much.. btw I am still typing this on a pink screen in search of a permanent fix...will be grateful if someone can help
por
Do you also feed some tea to the laptop? If yes, what kind of tea please? With or without milk? Please cause is important to keep the laptop happy
por
Ohooo.... My God plz help me frds.... Bcz 'am also getting same. Pink and green line in the laptop screen and the bottom side of screen is blinking non- stop... , frequently...It is teriable for me...
Plz give solution.
Pontuação 1
May be its because of your Graphics Driver . There is a case of getting this issue when we use Huge Graphics Softwares Which our system Can't run Can cause this Trouble. I suggest you to Install a new graphics driver
Pontuação 1
1 comentário:
Yes I think this too as when I closed gta 4 which was sticking very much so the screen was turned green and pink from that moment when I closed gta 4.....
por
This is due to several problems :-
  1. Operating System (Drivers)
  2. Hardware Problem.
To clarify just boot into BIOS of your laptop and see is lines still present ?
If lines disappear than your graphics drivers fault or that chip is damage.
If lines still shown in BIOS than your screen got damage. Just replace it.
Pontuação 1
1 comentário:
Right, but how do I "boot into" BIOS?
por
on desktop > press right on mouse > screen resolution > change resolution to 800 (apply-revert)> change to 1200 (apply-revert) > change to 1300 (apply-revert) > change to preferred resolution back. Thank me by pray for me so that I’ll be very rich in near future
Pontuação 1
1 comentário:
Waw... this actually worked! Thank you, so much. I tried everything and this is the only thing that made a difference. I recently upgraded from Win 10 to Win 11 on my HP laptop and left laptop on longer than usual after falling asleep and woke up to find pink and green lines just like the other users along with an annoying flickering screen. This is a real fix. I totally recommend using this.
por
this video i sthe solution for pink lines on laptop screen.it worked for me.
https://www.youtube.com/watch?v=4vUKudoF...
Pontuação 0
2 comentários:
Video Unavailable
por
video is not available
por
i have pink line (up and down)and i just got the laptop its a chromebook plus (samsung)please if someone knows anything help me fix this .
Pontuação 0
I have the pink ( white board) & green (black board) on my laptop. Everytime I leave it on the lines get thicker. Any others ways to remove it rather than changing the screen ??
Pontuação 0
first restart the pc and then, hold the screen with your thumbs and press it there where is the line seen. if not worked yet the continuously try it. it worked on my pc really….
Pontuação 0
This happens with my laptop sometimes, when it was happening again just now I tried pressing fn + f7 twice which on my laptop normally turns the screen off and then back on, and it stopped.
Pontuação 0
1 comentário:
por
Weird enough this got fixed when I turned on the night light. I thought night light filters the pink and green light and somehow make them unnoticeable. But that turned out be not the case. Even after turning off the night light, the fix remains intact until I restart the laptop.
Pontuação 0
https://howtofixgadgets.com/horizontal-l...
This may help you in solving my problem. Try using a different monitor if that will be OK then it's the problem with your display if it shows any problem then there maybe any software issue or any other hardware problem.
Pontuação 0
it's happen in my laptop every time when i carry it in the airplane, it seams that related to temperature or to the atmospheric pressure.
but it disappere after time, while running the machine, i tryed to stroke it by thumbs, It gets good result sometimes.
but really it's weird, hope to know the root cause and the solution
Pontuação 0
Adicionar a sua resposta
Aju krishna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 43
Últimos 30 dias: 211
Duração total: 173,742
