Ir para o conteúdo principal
error 13 writing is in Chinese
xbox plays games but I am unable to use it any other way becasue all the writing is in Chinese. Can this be fixed? I just purchased this for my child.
Update
Thank you so much!I was not able to fix. But a 14 yr old came over today who has an xbox ... Using you directions he got it going!!!!
Thank you because of you there are very happy 6 and 8 yr olds in my house.
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sharon, you can change the language setting on the Xbox360. Check on here and see if that helps. Now, if you can not read the menu (since it might be in Chinese;-) try this:"
Press the Guide button on the controller.
Go all the way to the right (the last blade).
Choose the 4th option, press A.
Choose the 1st option, press A.
Choose the 3rd option, press A.
Hopefully, you now see English in the list of languages. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sharon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 339
