ipad mini backlight, fuse is fine
I foolishly did not unplug the battery before disconnecting the lcd and digi so now my backlight doesn't work. I've followed the guide suggesting that I test the backlight fuse. so I tested the continuity and found that there is still continuity. what else could be the issue?
Esta é uma boa pergunta?
Pontuação
Did you find an answer? I'm having the same problem??
por none
i did a little bit of research and the 1 piece of material i found said that whoever posted it had this issue then found out that it was one of the capacitors. they didn't know which one so they replaced them all and that worked for them. for various reasons i couldn't attempt the same.
por thaddeus nall
