Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Perguntas Visualizar todos
Rescuing files from dead laptop's hard drive
My old MacBook Unibody Model A1342 late 2009 laptop won't start. The cause for this is probably a water damage.
Nothing major, just few drops of water in wrong place and that's that, so I'm sure that the hard drive itself isn't damaged. I'm not going to repair the laptop, but it would be nice to have the files from the hard drive.
What are my chances to rescue the files?
I viewed the guide for replacing a hard drive from this site and I'm capable to remove it, but what I should do next to rescue the files?
For example, am I able to connect the hard drive to PC?
I also have MacBook Air, so is it possible to connect the old internal hard drive as an external to it via usb?
Thanks in advance for any help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
of course tony, just buy a SATA/USB adaptor or case like this:
http://www.ebay.co.uk/itm/Slim-2-5-SATA-...
i brought cheapest usb3 case time ago, when i plug, it make an interference that stop network.
maybe find better one.
good luck!
Esta resposta foi útil?
Pontuação 5
1 comentário:
Thank you for your response! I will look for those that you mentioned. Even though I deal a lot with computers, I'm kind of inept with computer hardware, so I didn't knew how this kind of procedures are done.
por
Adicionar a sua resposta
Tony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 158
