Ir para o conteúdo principal
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
121 Perguntas Visualizar todos
Blinking green light after power outage on Mitsubishi WS-55511 TV?
My TV won't turn on after a power outage. I just have a blinking green light.
Will the fix described for "Repairing Mitsubishi WS-65511 Blinking green light" work on my older model?
Do I use the same 1000uf 16 volt capacitors that answer indicated? Where do I buy them since Mitsubishi doesn't have them on their parts list?
Thank you.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Jeanie Kansas, yes I would suggest that you replace the caps. You can get those from compnaies like Mouser.com or Digikey. com as well as many others. the blinking green light can also be caused by the DM module's EEprom is intermittently bad.
Esta resposta foi útil?
Pontuação 1
Hi,your tv needs the dm power board repaired,we do this repair from e b,ay.search for listing #330700000004.on main search bar.
Pontuação 0
Adicionar a sua resposta
Jeanie Kansas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 534
