Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Perguntas Visualizar todos
It won't start or turn on
Washer will not start
Kenmore 110
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
2 respostas
Pergunta mais útil
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Check and make sure circuit feeding washer is live try plugging a working lamp into the plug with the washer to check
Update
If the lamp doese’t work go to the inside breaker panel and look for tripped breaker normally it will be a 15amp or 20 amp depending on how the circuit is run
Esta resposta foi útil?
Pontuação 1
Unplug the machine for 5 minutes to allow it to reset.
Pontuação 1
1 comentário:
Mine worked by resetting
por
Adicionar a sua resposta
gene4unot será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 7,618
