iPod Touch got wet, won't turn on
My iPod Touch was exposed to a little water spray. It was dried quickly and continued to work. The next day it went dead and it won't start.
Esta é uma boa pergunta?
well you voided your warranty, because they have a substance hidden in the headphone jack connector that will turn red when exposed to water.. try a reset. press the power and home button at the same time for maybe 10 secs till the apple comes up (hopefully)
Esta resposta foi útil?
Thanks Michel, I tried to reset it every way possible-no luck. Is it servicable, should it go to Apple or will I do better somewhere else?
first of all - forget the idea of bringing it to apple - they don't care.
there is something you could do:
disassemble it using the logicboard guide for your model
you will find some white/greenish residue on the logicboard
get isopropyl alcohol (>90%) and clean those parts carefully with a soft paintbrush - the residue is conductive and shortens the parts - thats why the iPod won't work.
let it dry after you're done and then reassemble it, if it's not powering on, try to charge it
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 6,334
