Colored vertical lines on screen...
Ok so I have replaced screens on many iPhones before this one. This is the only iPhone I have had so many problems with. I don't use aftermarket screens when I fix a phone so I figured thats not the problem. Well I than put the screen and everything back together and then I get the white squares at the bottom of the screen. I was puzzled because this has never happened to me before. So I re-opened the phone and made sure everything was connected and it was. Then I boot up the phone and these colored lines appeared on the screen. The digitizer is un-responsive and I cannot figure out what is going on...
*It has also reset the date back to December 31, 1969... I have no clue why it does that...
Esta é uma boa pergunta?
You have to view the original image to see the lines. In real life they are very noticeable. You can clearly see the white squares returning.
por Dalton
