Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2191 Perguntas Visualizar todos
Which cable powers the backlight?
Hello...
When looking at iPhone 4S Screen Replacement Step 17, I see the digitizer cable and the display data cable. What powers or control the backlight part of the LCD assembly. I have tried 2-3 supposedly "new" LCD for my iPhone 4S and none of them have backlight.
There was some damage to the phone and I'm trying to pinpoint where the problem is. The rest of the phone works great; with a light pointed at the screen, I can use iOS to install apps, use apps, connect to Wifi, charge, access from iTunes on desktop.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
If you have tried several replacement screens for your phone and all are giving you the same issue, perhaps the fault isn't with the screens. Have you considered the possibility that you have a damaged logic board?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I was really hoping it wasn't the logic board. From what I've seen online, I would need to replace the backlight coil, IC and filters. Need to learn to solder I guess.
por
Adicionar a sua resposta
Sccoaire será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 169
