iPod Touch 2G won't charge after battery was replaced?
In the process of replacing the battery, I accidentally pried the middle connection of the battery from the circuit board. A small copper foil where the middle wire/ribbon of the battery is soldered came off. I still replaced the battery hoping it's nothing important. After putting everything back together, it still worked fine. But when I connected to my computer and even the wall charger it won't charge anymore. I think it's because of that thing that came off. Can you post a photo of the circuit board with the solder removed so I can see where the battery is connected? Can you tell me where I can solder it to so it will charge again? Thank you.
Esta é uma boa pergunta?
