Ir para o conteúdo principal
Can't get my PSP 1000 to hold a charge.
I have had my PSP for a while now, about three to four years and for some reason, my PSP cannot hold a charge. I can charge the PSP and use it with or without the battery, but as soon as it leaves the plug, it dies instantly. Anyone know if this is a problem with the PSP or just the battery?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
sounds like the battery is completely dead - since it's a fat psp and you own it for 3-4 years - it's almost normal that the battery died.
(many psp batteries died earlier - 3-4 years is a very long time)
Esta resposta foi útil?
Pontuação 0
sounds like your battery is broken and your battery needs replaced,or
  • get a friends battery
* check for metal stuff shorting out the battery power
  • use the charging wire and check the amount of battery power there is
Pontuação 0
Adicionar a sua resposta
ColinHuang001 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 8,729
