Ir para o conteúdo principal
Released September 2013, the Visual Land Prestige Pro 7D model number ME-7D-8GB is an affordable and sturdy tablet designed for kids.
26 Perguntas Visualizar todos
Why won't my device charge?
I tried charging my device using the supplied cable which is in good condition and it didn't work.
The device is out of power and I can't get it to turn on. Up until now my device would charge but would lose its charge faster and faster.
It showed a low battery icon the first few times I tried to turn it on after it ran out of battery, but now it doesn't do anything.
What should I do?
Esta é uma boa pergunta?
Pontuação 5
2 comentários
how can you tell when the battery is fully charged.does the battery icon ever supposed to turn green mines stay yellow.
por
Had the same problem with my tablet charge it and boost and it still wouldn't come on . Got a new charger and the same thing what is wrong with this tablet only had it six months.
por
Adicionar um comentário
2 respostas
Solução escolhida
Your battery may need to be replaced. Follow the Battery Replacement Guide for instructions. The guide can be found here.
Esta resposta foi útil?
Pontuação 1
Trash it. Cheap tablet. They supply defective xformers which overheat, short out and blow the Charging circuit inside the tablet. Mine lasted less than two weeks.
Pontuação 0
Adicionar a sua resposta
Max Hudson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,696
