MBP Retina is not turning on after water-damage
Hi
i have a MBP Retia with a water damage. Everything is now dry an cleaned.
As you probably guessed, the MB doesn't turn on, if the power button ist pressed.
A PC-repair-shop siad, it is probably the logicbaord. But befor i buy a new logicbaord, i want to be sure, that's realy the problem. i heard that it's often something else.
when i connect the magsafe-powercoard it turns orange after 3 seconds. So this means it is loading, right?
So i tryed to bypass the powerbutton by connecting the 2 pins on the logicbaord-keyboard-connector.
When i do this, the LED on the magsafe turns green for three seconds and then back orane. nothing else happens.
what does this mean? the logicbaord can't be completly dead, right?
can you help?
Esta é uma boa pergunta?
