Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
Vertical lines on half the screen.
Is this fixable?
The left halve of the screen has vertical lines and images stayes after moving the windows before it slowly fades away. Also flickering.
Apple charges 2/3rd of the price of a brand new one which is totally unacceptable.
Is there a way to repair it myself?
Kind regards.
Ps: no warranty or any other help from Apple.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
007rip, not seeing what you see and just going by your description, it sounds like a bad panel. You do want to disassemble your monitor and make sure all cables are still properly connected, but right now it appears to me like you will need a new display.
Esta resposta foi útil?
Pontuação 1
Thank you.
So you seem to know stuff.
I'm trying to replace my 27" Cinema Display's LCD but I'm unsure about compatible panels.
I need LM270WQ1(SD)(B1) but do other panels work too? Like the ones for the 27" iMac?
Btw, it's not the Thunderbolt-version.
Thanks!
Pontuação 0
Adicionar a sua resposta
007rip será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,029
