Pular para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
317 Perguntas Ver todas
Brainstorm: iPad2 was dropped, now black LCD but backlight works
A dropped iPad 2 has been brought to me by a client. LCD screen is black but backlight turns on. I did some research and it seems there are two reasons this is happening: 1. The LCD is bad, or 2. The logic board has a broken circuit or jumper that needs to be bridged/resoldered. I really don't want to have to open it unless I know for sure what I need to fix. Can a backlight still work if the logic board is the problem? Is there anything I can try, short of opening it up, that can help me pinpoint what the solution would be? I don't have the proper soldering equipment yet, so I don't want to open it and then realize I'll have to send it out for resoldering. Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 Soluções
Resposta Mais Útil
Hi,
I can't understand you well. The screen can't be black if the back-light is working.
You can't be absolutely sure without opening and replacing the LCD display.
Yes, there is solution for a not working back-lights. You must replace or make a jumper for one coil. But this is solution for not working back-lights. In this situation you can see an information on the screen from a specific angle.
But if you haven't information on the screen and if this happens after a hit, 90% the problem is with LCD display. Inspect the LCD from different angles. Maybe you can see a small rift somewhere.
Without opening and testing with another LCD you cannot be sure where is the problem.
Regards.
Esta resposta foi útil?
Pontuação 1
Hello this can be simply fixed by opening up disconnecting the lcd and reconnecting and in most cases it will turn on with no problems..
This is a common fault in the iPad2 with the lcd disconnecting when dropped..
I'd it doesn't work then next step is a lcd replacement if a new lcd doesn't work it's a board problem..
Only way to find out is to get stuck in and open it up..
Don't understand why you won't open it up and troubleshoot the problem
Pontuação 1
Adicionar a sua resposta
PCHookups será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Todo: 694
