I tried physically reseating my RAM and that worked for a while, but the problems reappeared and the frequency increased. At first, the 3 beeps would sound if I moved my laptop to another room, but soon, I only had to look at it wrong and then I’d get lines across the screen, everything would freeze, then my laptop would shut down. If I tried to restart it, yes, that’s right: 3 BEEPS!
This is REALLY a pain because a laptop is supposed to be portable.
I was just considering the necessity of purchasing a new laptop that I currently cannot afford AT ALL, when I came across this video:
https://www.youtube.com/watch?v=VLZhClQ_...
It is in Italian, but what the tech does is pretty clearly demonstrated, and someone in the comments section explains it in detail.
Basically, you insert something non-conductive underneath the bottom RAM slot, and that stabilizes the RAM so that the laptop stops this lines, freeze, shut-down, 3 beeps thing.
Do yourself a favor and watch this video! I followed the instructions yesterday and my laptop is back to its old, reliable self.
Oh, and apparently this seems to be a problem frequently experienced by owners of 2012 13-inch Macbook Pros (my model exactly).
7 comentários
adaptor plug then automatic on coming beeps3times. repeating 3 beep no display
what can do pls answer
por muhammed
Last week I had a similar іѕѕuе, my macbook Pro could not start and it would just beep three times.
Finally I managed tо fix this after getting help from Apple Mac support
Follow the steps here: http://bit.ly/MacPro3Beeps
It should solve the issue
Goodluck
por Candida
Careful about going to that link. They wanted to saddle me with a 200 dollar a year "security networking service" and were really pushy about getting my credit card number. Kinda sketchy.
Anyway, I figured out my issue because my battery didn't have enough charge when I turned it on. Plugged it in, waited a few minutes, restarted, works fine now.
por voodazzed
Hi, I also have the same issue, many videos point the problem to the RAM, in my case, it is not the RAM, I unplugged the HDD, the battery and the RAM. When I plugged all over again, the problem is solved.
por Mário Miranda
I had same problem but after removing and re-insurting ram it dis not work out... so i again removed it and switched them... i inserted first one first and the bottom one on above... and it worked
por Shashwat Singh
Exibir mais 2 comentários
