valve cover gasket on passenger side
Hello just wondering how would you go about changing a valve cover gasket in a jeep liberty 04 v6 passenger side mine seems to be leaking bad
Esta pergunta é pertinente?
ilya, from the service manual:"
REMOVAL
(1) Disconnect negative cable from battery.
(2) Remove the resonator assemble and air inlet hose.
(3) Disconnect injector connectors and un-clip the injector harness.
(4) Route injector harness in front of cylinder head cover.
(5) Disconnect the left side breather tube and remove the breather tube.
(6) Remove the cylinder head cover mounting bolts.
(7) Remove cylinder head cover and gasket.
NOTE: The gasket may be used again, providing no cuts, tears, or deformation has occurred.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,393
