Why is my tablet not vibrating?
My device does not vibrate while being "ON".
Esta é uma boa pergunta?
You should start by checking the tablet's settings. If this does not work, you might have to check the internal wiring of the tablet or check for water damage. Lastly, if none of the previous steps work, then you probably have a problem with the tablet's vibration switch. To remove the vibration switch click on the Vibration Switch Removal Guide and follow the steps.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 959
After doing some research, I believe that I have found the answer to my own question.
por Gabriel Delgado
