Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Can't find any networks
For five days now I haven't been able to connect to any networks at all. My airport is on, it just can't find any networks, none show up. Not my own, not my neighbors. I've done all the normal things to make it work, I even checked my router. My phone and every other device can connect, so it's just wrong with my MacBook Pro. I really don't know what else to do. I trouble shooted my entire computer, I did the advance setting checks. I'm not well betced with computers so if anyone can helper me know.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Sounds like the AirPorts transceiver has given up the ghost or you got the AirPort board wet and the antenna connections are corroded.
Sadly this is a very big job as you need to take almost the complete system apart to get to the AirPort. Here's the IFIXIT guide for you to review: MacBook Pro 13" Unibody Mid 2010 AirPort Card Replacement.
I would locate an Apple authorized service center or Apple Store near you and let them deal with this repair.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Wow thanks so much!
por
If this answer answered your question please remember to rate (score) and mark it accepted.
por
Did this work for you? This wifi problem is excactly what my 13" MacBook Pro (2010) is currently plagued with. The OS is recognizing the network card so I was hoping it to be a software problem. Mahalo. @robertspina21
Pontuação 0
1 comentário:
There are two sides to the card: The digital side and the analog side (radio part).
What can happen here is the radio side can have problems so the card still looks good but doesn't work.
Try this press the Right side Option & Shift keys and pull down the WiFi icon on the menu at the sometime. Do you see the signal levels? If not your card is bad, if you do its possible the antenna lead is broken.
por
Adicionar a sua resposta
robertspina21 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 251
