Why won't my computer read any CDs or DVDs?
When I insert a CD or DVD into the CD drive, the computer won't read it and doesn't recognize that I've inserted a disk. The computer is working fine other than that.
Esta é uma boa pergunta?
Hi there! We have a few ideas that might help you out. Try following these steps:
First, you have to make sure your computer recognizes your optical drive. Check in your resource manager and see if the optical drive icon appears. If not, restart your computer and look again. If it’s still not there, your problem is with your hardware. You can call Lenovo services or check out our CD drive replacement guide!
Check your computer manual make sure that your model is capable of reading the type of disc you’re asking it to. Then check if you’ve inserted the disc correctly and that it has no defects (scratches, dirt, warped.)
Your drive might just be dirty! Grab a can of computer duster and get into all the cracks and crevices of that thing. Can’t hurt.
If it still doesn’t work, you probably have a hardware issue. You may need to repair a part of the drive or replace it all together. They get worn out over time. Take a look at our replacement guide on how to do it yourself.
Esta resposta foi útil?
It was not helpful at all
@kittens003 if there is a problem we can help you with please open a new question with detail of your problem . these answers are of help to some but may not suit your needs if you could give use more info on your problem we can help
What happens when you insert the disc? Are you getting any error messages when you try to play the DVD?
The disc should start playing automatically. If it doesn't play, or if you want to play a disc that is already inserted, open Windows Media Player, and then, in the Player Library, select the disc name in the navigation pane.
These guys must work for lenovo and profit from sending you in the wrong direction . I have upgraded to windows 10 several times and every time I have to go to the legit lenovo site and download the software free for the dvd/cd .
Thanks for the useful information!It was very helpful.
you need to clean your dvd or cd drive and check all connections are ok. if it is still not working then you need to replace your dvd drive and check. is it working now or not ?
Clean the dvd/cd and connections yes . Replace dvd drive not likely. 1ST Go to manufacturer and download software free .
First step
you need to check a cable connections always compatible to your dvd/cd rom.
Then go to the bios setting and find the deafault setting and save.
then try to boot.
check the cable yes , bios no. manufacturer has the software free.
how do I change bios setting?...why don't makers do this before selling?
f the bios just download from manufacturer
New of the box. I tried several new disks. /Nothing happens. The drive spins and stops. no disk icon.
not helpful at all
The previous comments are from idiots’ or scammers , just look for the cd/dvd software from your pc manufacturer . Thats it . Oh yeh it’s free!
I don’t need more reputation to vote someone down . I just need the correct answer .
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 64
Duração total: 107,484
13 comentários
my dvd drive worked great until I loaded windows 10. now it doesn't even recognize that I have a dvd drive
por jerry
My desktop is a HP and I too downloaded windows 10 since then no DVD's I can however download games from a DVD
por Deborah Altman
Hi @Deborah Altman,
What media player are you using in Win 10 for your DVDs?
Go to Start > Settings > System > Default apps > Video and see what apps are available to use.
por jayeff
Windows 10 didn't ship with a default DVD player. You will need to download a 3rd party app or Windows DVD Player from the Windows Store ($14.99) to play them. I use VLC and it works well but there are several other options too.
por bmh67wa
I Have a dell Vostro410 thats allowed me to play CDs 7 DVDs happpily. I Have not downloaded a new system at all. I already have VLC player but suddenly nothing regonises that a disc has been put in the PC at all
por Andy Ray
Exibir mais 8 comentários
