Ir para o conteúdo principal
Won't power on, vibrates every 5 seconds, with replacement battery.
So my battery has seen better days, won't last a whole day (with very sparing use, I'm not a phone junkie) and sometimes dies at like 35%.
I figured it was time for a new one. Ordered the best reviewed kit on amazon.
The replacement process goes fine, and I get the phone all buttoned up and plug it into a charger... and it just sits there with a black screen, vibrating like it's recognizing a power cable every five seconds.
Now from what I've seen online, this has to do with a damaged display, or at least damage to the connection between the motherboard and the display.
So I check the connection, nothing is damaged or kinked, but I disconnect and reconnect the cables and try again. Same symptom. I then reconnect my old battery (failing, but at least with some charge and known to work) and the phone boots right up.
Is this a bad replacement battery? A battery that just needs to charge for a while to get up to a useful load? Something else wrong with the phone?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
UPDATE: Turns out it the flex connector for the LCD was getting disconnected as I put the phone back together. I used a tiny piece of tape to hold it down and the new battery is now working fine!
por
Adicionar um comentário
2 respostas
Pergunta mais útil
I got it working!!!
I had the same vibration every 5 seconds & black screen after replacing a cracked display & plugging in my i-phone 5. I was so frustrated & spent over an hour re-seating all the ribbon cables several times over & everything looked good. Finally I took the advice of someone on one of these forums --- held down the lower round button & the top on/off button at the same time, for 15 seconds until the white apple showed up on screen. I let go & it came alive!!! I was so thankful my prayer was answered.
Esta resposta foi útil?
Pontuação 1
Sounds like you have a back battery, try another one.
Pontuação 0
Adicionar a sua resposta
Corry Fox será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 3,728
