Ir para o conteúdo principal
Model A1046 or A1095 / 1280x854 screen resolution
155 Perguntas Visualizar todos
Can a broken latch be replaced?
I don't have a problem with the two little hooks coming down. My problem is with the bottom mechanism. It looks like a piece of the metal that holds the hook broke off.
I've read that the bottom needs to be replaced, but my question is, it looks like that piece is glued on. Does anyone know if I can cut this off and re-glue another latch on?
Thanking you in advance. Mackdog
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Are you talking about the latch that holds the displays lid down?
por
Adicionar um comentário
1 Resposta
Solução escolhida
Yes - your best source for this part would be e-bay, you may have to purchase an almost complete "for repair only" unit to secure one.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 0
Comentários:
Thanks for the help, I appreciate it!
por
Adicionar a sua resposta
N Little será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 102
