wifi on train issue, can connect but then get url/error
Has connected fine in the past but suddenly stopped, sign in ok but when accepting terms and conditions I get THE REQUESTED URL/ERROR.html was not found on server
Esta é uma boa pergunta?
The server you are trying to connect to appears to have an error with the URL. Try other sites to see if the problem is present with them.
Try connecting when you are at home or at work accessing the same server, is it working?
It's possible the session to the server is being lost as your train is jumping from one connection point to another as the train is moving (not your WiFi connection within the train).
Some methods of how the web server is configured may not be able to handle the hand-off between the different connections.
Try establishing the connection when the train is standing still and see if you can continue to access the server when the train is not moving. Then see how it reacts as the train starts to move and moving down the tracks does it loose the connection? If it does there is nothing you can do as the issue is on the given server.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 665
