Ir para o conteúdo principal
Harley-Davidson Sportster Motorcycles from 1986 to Present.
34 Perguntas Visualizar todos
Pergunta encerrada
Battery terminal melted battery connection what do I look for?
When I started my 2000 sportster-xl 1200, I smelled smoke and looked down, and my battery terminal were melting! My friends say there is a Short some where. Where do I look at on the bike?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
It might only be a loose connection of the battery cable. My brother replaced his battery in his '06 Sporty. Unknown to him the negative cable loosened when sliding the battery back into place. When he tried to start it the negative terminal (the boxy cage type not solid kind) melted from the loose connection. If you look at pics of different motorcycle batteries you will understand what I mean. I hope this helps, Steve.
Esta resposta foi útil?
Pontuação 0
check connection at the battery first
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,609
