Rear Speakers - Sound issues
Hi Guys,
My macbook sounds noisy and unclear. But, on head phones it very good. Will it be a hardware issue? or could it be software related?
Esta é uma boa pergunta?
Hi Guys,
Did someone spill a drink into the keyboard? I've had a few systems which had soda spilled which with the dust from the fan messed them up.
I would start by doing a good job cleaning up the dust within the system and replace the speaker. If something did get spilled you'll need to clean it up as well.
Esta resposta foi útil?
Hi Dan - Did not spill anything. I started noticing this over the past 3 months and I thought this could be because of Windows 8 I am running as dual boot. Thought it might to do something with drivers?
I tried cleaning the Fan and pulled out the rear speaker and cleaned it , but no luck. Do you think, it is just the speakers' hardware? and I get this irritating noise when the volume is above 70% , below, its difficult to hear anything :)
Is it a buzzing sound? It might be something loose which is vibrating when the speakers volume and/or tone is just right to set it off. I've found loose parts are often the cause. See if you can find a tone generator app to walk through the different tones. Something like this: AudioTest
Frankly, the built-in speaker is not very good in this model. You might find a JamBox or other plug in external speaker will offer better fidelity.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 271
2 comentários
Could be your speakers. should not be a software issue since the audio IC will remain the same. Could be a preamp issue. I'd go check the speakers first.
por oldturkey03
Thanks mate.
por Srini Krishna
