Ir para o conteúdo principal
The Cuisinart Mini-Prep Plus DLC-2A is a compact food processor that has been in production since 2001 and retails for about $40.00.
Why isn't my Mini-Prep Plus turning on?
The chopper is not responsive when the chop or grind buttons are pressed.
Esta é uma boa pergunta?
Pontuação 6
1 comentário
I've only used this machine a couple of times and it worked perfectly. Went to use it today and no response. I've done all the trouble shooting tips.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Also, ensure the plastic tab of the bowl cover locks into the slot on the back of the machine. This will short the safety switch.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you so much.
Saved me buying a new one.
Philomena
por
Bought mine at a yard sale and had no idea. This was the fix. Thank you.
por
Check and ensure that power cord is plugged in. If the power cord is plugged into a working power outlet and there is food inside the workbowl, try removing some of the contents and attempt use again. Failure to "turn on" may be caused by overloading the workbowl to a point where the contents prevent the motor from functioning properly.
Pontuação 0
Adicionar a sua resposta
Nancy deGorter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 6,632
