Can I use the same way to change battery in Triumph 5000?
Can I change my Braun Triumph 5000 battery the same way as 9900?
I am so glad I heard about you in a documentary about consuming!
Marianne in Sweden
Esta é uma boa pergunta?
Marianne in Sweden
Yes, it uses the same battery as Braun Triumph 9900. Amazon lists it as same device. You can also find on eBay battery that covers both devices.
Verify with your old battery before purchase as Oral-B uses shorter battery outside of USA. The one sold in USA is 48mm L x 17mm D. The other size is 42mm L x 17mm D.
You can them with care976 or intergribiz. You can find other sellers on eBay.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,148
