Samsung vs LG compatibility
Hi,
does anyone know if all A1369 polarizer panels are compatible (LP133WP1 TJ A1, A3, A7, LSN133BT01)?
Thx!
Esta é uma boa pergunta?
Hi,
Thx!
21dcba, since the polarizer sheet depends mostly on the physical size, they should be compatible as long as the size is identical. You definitely want to make a guide if you change the polarizer. I've only seen it done once and it is not an easy task at all.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 104
