Ir para o conteúdo principal
Lançada em outubro de 2011. A segunda geração de filmadoras externas da GoPro, usada por atletas profissionais, entusiastas de esportes e usuários dedicados.
Doesn't start up after not using several months
GoPro worked well but after not using it for a few months it doesn't startup.
Checked battery = charged
Tried battery of a friend: same problem.
Searched the internet and found information that this happens more often. Soft- or hardware problem?
Does this sound familiar?
Does anyone have a solution?
Esta é uma boa pergunta?
Pontuação 4
2 comentários
The same situation for me. Hoping to resurrect it, as it ought to have considerable life left.
por Compartilhar
Same issue with GoPro6Hero. I have three charged, one 3 battery charger, batteries, two charging cables, and two charging ports, and I have tried everything I have read to do. Still no signs of life.
por Compartilhar
Adicionar um comentário
5 respostas
Pergunta mais útil
Having a good background in electronics, I can only suggest this:
1- Make sure that the battery is in good condition and that it is fully charged. Some rechargeable batteries that have not been used for a long time might give wrong voltage readings because of their faulty condition. They just do not deliver the necessary electric current/power. Get a new battery.
2- Make sure that the battery contacts are clean - also inside the battery compartment of the camera. Storing batteries inside an electronic unit for a very long time might result in corrosion of the contact terminals that will create high electric resistance, not being able to power up the unit - not to mention a degraded state of the battery. Clean the contacts. A new battery might be needed.
3- Has the unit been exposed to any falls or mechanical vibrations? This could have damaged or displaced any mechanical contacts/parts inside it. Get someone qualified (service technician) to check it. It could be fixed, but it could also not be worth fixing it.
4- Should points 1, 2 and 3 be ok, we are then talking about a *really* faulty unit. Has it been exposed to very humid air during storage? Salty atmosphere (by the beach)? This could corrode the terminals and electronics inside it. Sorry, but the only way to fix it is by getting a new unit and battery.
Hope that this helps.
Esta resposta foi útil?
Pontuação 4
1 comentário:
Tried all that and it is still dead. It was working a couple of months ago, and then went to use it and NOTHING! :-(
por Compartilhar
about 1-2 years ago i bought a 2nd hand gopro hero 2 that also wouldnt start anymore,
the guy didnt do anything specific with it, it just randomly stopped working,
if i remember right the light did turn on if he connected a charger/usb cable but never managed to turn it on,
i looked on the internet and found some people that had this problem and fixed it by putting the gopro (in a sealed bag) in the freezer for a while and after taking it out turn on the gopro and it would work, then directly charge it and it should be in working condition again...
i hope its not too late and all, would be a waste, look it up on the interwebs..
Pontuação 0
Try cooling it in refrigerator over night, then install battery and turn on. Worked for me! It defies logic but was last chance before I tore into it and checked C11 on mobo by lens as directed by another user. It's a 47mfd tantelum surface mount cap (476) that failed on another user. I'm not sure if it was the temperature or the drying effect of the dry refrigerated air that did it.
Pontuação 0
might have to open her up, check with multimeter on DC voltage less than 20v the connection from battery to board, then if no voltage when turned on check power switch if connection exists when depressed. Voltage should drop when checked on board connection. If unable to do any due to lack of knowledge drop it off at a tech repair store.
Pontuação 0
Ok I just tried the freezer thing and it worked!!! Put in freezer inside a plastic Ziploc bag left unsealed as I figured the dry air theory wouldn't work if sealed. Did the hold power button 8 seconds it then started as normal. So happy:) for ref gopro hero2. Thanks everyone in this thread for sharing your knowledge.
Pontuação 0
Adicionar a sua resposta
Paul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 39
Ao todo: 5,038
