Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
Water damaged, Can't restore, error 2001. Battery replaced.
Hi there!
I've received a white iPhone 4s, which was dropped in water. It was completely dead, but when connecting it via usb to a power source, puts it in a boot loop. I'm able to get the device into both normal recovery mode, and in DFU mode. Restoring in either of these modes via iTunes, yields me a 2001 error. I read some places that replacing the battery could fix the problem, which seamed logical to me as the device seemed to function (Screen works, DFU & Restore mode), only when connected to a power source.
I ordered a battery, replaced the old one, but even though I've replaced it, and spend quite some money on it, i'm still where I started. I still get the 2001 error, the device still doesn't do anything without being connected to a power source. Just like before.
Anything I can do to still save this thing?
EDIT: The error given on my windows laptop when restoring is 21, not 2001.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Firstly I would take the motherboard out and give it a good clean with alcohol then check the actual battery connection on the board if its loose or residue. Try new battery after. Error 21 is battery related hope it helps
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 619
