Battery not charging dim magesafe light
Helllo dear fixers :)
My macbook wont charge the battery in any case, but works of the battery as well as the power cord, but once the battery is drained it wont recoginse it anymore and also it never chrages it. The light on the magsafeplug is always a very dimmed green, regardless if battery is installed or not.
I read a lot and i was thinking to replace the left IO Board but then i read that in some instances (not exaclty like mine) the problem would be on the logic board.
Any advice? shoudl i give the IO Board a try?
Thanks a 1000 times
josh
Esta é uma boa pergunta?
1 comentário
Also, i tried several battery and charger….same behaviour
por Joshua
