Ir para o conteúdo principal
The dual SIM version of Nokia's C2 series, released in 2011.
How do I re install software on my dead Nokia C2-00
I came across this software update notification on my C2 after which i choose download and install. All went fine until the end when it finally restarted and gave a message" contact Service in white and the screen was a ll black. I tried to switch off but it was all non responsive. Now nothing comes on so am here to know if this is salvageable or I just forget it.
Regards
Zed
Esta é uma boa pergunta?
Pontuação 20
Adicionar um comentário
6 respostas
Pergunta mais útil
have you tried to take battery out, and re-insert into phone. What happens if you do that?
Esta resposta foi útil?
Pontuação 4
3 comentários:
..Apparently yes, I recharged the phone just to be sure but even then, nothing came on the screen to show charging was in progress so after that I have removed & reloaded the battery, tried to power it but nothing comes on...
por
Then i would contact warrenty, because if the issue is data corruption or damaged certificate - it can only be fixed in a service center using a flash jig.
por
Ganon pare pag ginwa mo tan
por
Same Issue i want nokia c200 os software
Pontuação 2
Hello, I am also facing the Same Issue :( is There any Solution please?
Pontuação 1
I am also facing this problem in my Nokia C2-00, I removed the battery and again inserted in the phone but it is not working, my phone is just showing white screen.
Pontuação 1
hardware id pass word forgoten .kinly send me nokia C2.00 soft ware id pass word
Pontuação 1
muje mobail pdet karna he
Pontuação 0
Adicionar a sua resposta
zbundi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 20,448
