Ir para o conteúdo principal
won't charging or conecting in my computer
hello i have ipod touch 2nd 32 GB
so i have problem its about i can't charge it or conect it with my pc its still turn off ... but it was working fine i understand what hapend
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
Take a look at your dock connector on the iPod do you see damaged pins?
por
Adicionar um comentário
1 resposta
I just experienced the same problem with a used gen 2 I purchased yesterday and the fix is as follows. The battery has drained so low that it isn't recognized by the charger, so the battery needs to be "jump started" so to speak. The same goes for many batteries in devices and even auto's and motorcycles.
So, with the charger plugged into the wall, carefully plug-in & unplug multiple times until it responds and begins to charge. What this does is gives the battery a small "jolt" each time until it can be sensed by the charger. It took my device approximately 15-20 times, so be patient.
Good luck bro.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
SIMO STUNT LOVER será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 87
