Replaced iPhone screen turns off and on now?
I just recently replaced my iphone 5s screen and everything was good until I went to power on. I just got blue lines and the screen glowing up and it cycling on and off. I dont know what happened or whats going on but when I went to check my work the connector closest to the batttery was lose and doesnt want to lock in place also the vertical one directly above it. I dont know if I messed up the connectors or something else but my phone wont do anything. I saw a picture of a low battery logo pop up for a second and that was about it. Anyone have any issues like this and can point me in the right direction? Thank you guys
Esta é uma boa pergunta?
Blue lines while your phone is turned off?
While phone is turned on , If you have a mix of pink , then blue , then yellow colors appearing on your screen that means your screen is having issue and need to be replaced
Otherwise I don't think you have a screen problem ....try to charge it and do the unfreeze procedure ....It might help
por Bassel
Other thing that might also help , try to remove the screen and connect it again properly without using a metal screwdriver ....the connectors might works fine
por Bassel
