Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
20 Perguntas Visualizar todos
Broken Screen replacement, half the screen doesn't work, it has lines
Hello there
I dropped my iPhone 5s and now half the screen has white thick lines going through it, I can't press over it, I can only use the right side of the screen. What should I buy to fix it? There must be a problem with LCD? Screen is not cracked though.
Esta é uma boa pergunta?
Pontuação 48
2 comentários
I want to know if I get my screen on my phone change will I lost contacts on my phone, and I will my phone be unlocked or not if it has been disabled and I need to know like ASAP going to get my iphone fix tomorrow by the way my iphone isn't broken need to get the screen fix .
por
I had this problem to i spent 80 bucks to get it fixed
por
Adicionar um comentário
14 respostas
Solução escolhida
Make sure your first connector you press down dosent look like this slightly bent in pic 1
If it does then you will have to bend it to look like this in pic 2
I'm positive this will 100% fix your problem
Esta resposta foi útil?
Pontuação 10
6 comentários:
No it wasn't helpful firstly only one side of iPad works and got a line on one side of iPad so don't know what is wrong with it
por
The answer and post is for an iPhone not an ipad! So the answer is helpful!
por
What kind of connector is that
por
You are very gay
por
You have to throw it away and go buy a new one from the local 7-11 or go to any 7-11
por
Exibir mais 1 comentário
Hi
The problem could be as simple as either rebooting the iPhone or opening the iPhone and reconnecting both the LCD and digitizer connectors since in some situations it can become loose after dropping the phone.
You will need a pentalobe screwdriver, #00 philips screwdriver, plastic spudger, and a suction cup (or iSlack tool) to open the iPhone and diagnose the problem. There are guides on here for the 5S that will greatly assist you with opening the iPhone.
Open up the iPhone, being careful with the touch id sensor flex cable, disconnect the battery, and then remove the metal shield that covers the screen connectors and take a look at the connectors. Remove and reconnect them and see if that solved the problem. Lemme know if you need help or more info.
Best of luck.
Pontuação 5
2 comentários:
could i just replace the screen and it fix?
por
I have an iphone 5c. But I dropped it and now when I open it the creen opens but it doesn't work when I touch it. Can I repair this to a repair store? Please answer me. How much does it cost if I can repair it?
por
con, all connectors seems ok. but the right half of the screen has stripes and not response my touches
Pontuação 3
While albiejames is correct. I normally see white lines, when using a bad part, or when there's connection issues, with the digitizer cable and socket. Guessing this all happened with a stock phone so try this guide, and be careful while doing it
iPhone 5s Screen Replacement
If you need to, here's parts. In case you need another
iPhone 5s LCD and Digitizer
Imagem de Replace a front glass digitizer panel or malfunctioning 4 inch IPS LCD display compatible with the iPhone 5s. Features a 640 x 1136 pixel Resolution.
Produto
$39.99
Pontuação 1
i need help
Pontuação 0
1 comentário:
dd, with what?
por
I dropped my phone about a month ago, and cracked the whole screen. Except for the part where my whole screen was cracked, it was working fine. Then I dropped it again and a few pieces of glass fell out of the top right corner. White lines developed and the right side of the screen wasn't working. The white lines are gone now, but the whole right side doesn't work. I can't get into it because part of my password requires a number on the right side. Help!
Pontuação 0
6 comentários:
Did you find a way to fix It same thing happened to me :( ^
por
Same thing happened
por
yeah thats what happened to me.
por
same man. idk
por
Same but idk if it can be fixed or not
por
There are no cracks at all just the left side of my screen wont work when i press down or even a little
Pontuação 0
if my phone was droped and only the lefted side had gotten hit...
and now there are black lines and some what of white lines accross it...
dose that mean my iphone screen needs to be replaced..
Pontuação 0
https://www.youtube.com/watch?v=nJCZJwrk...
https://www.youtube.com/watch?v=0UzIEN3N...
This videos will help
Pontuação 0
my iPhone 6 has been cracked and the screen has red/purple lines running down the display and the touch doesn't work. Can this be fixed if I take it to someone????
Pontuação 0
2 comentários:
Yes or you can fix it yourself. If your wondering how watch the videos on my previous comment
por
i have the same exact problem if someone replys to u pls tell mr what they said so i can fix mine
por
Hello there
I dropped my iphone not too long ago and it had white,blue,red,purple lines going through my phone and i can only use the right side of my screen i tried going on websites,youtube,google and trying to search ways to fix my iPhone.Please give me ways to fix my phone without any tools.
Pontuação 0
have galaxy core prime and has same problem
Pontuação 0
same exact thing happened to me, you need to get the screen replaced, it is a hardware issue,
Pontuação 0
HELP MEH!!!!! I dropped my phone multiple times and now the screen doesn't work! I turn it on and can only open my phone with my touch ID because it takes about 10 seconds for the screen to somewhat work. Once I get into my phone, the right side of my phone slowly turns black, but continues to slowly work somewhat. I click an app and what ever my screen was last on, stays on the right side.
Pontuação 0
1 comentário:
por
Adicionar a sua resposta
Jagoda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 149,097
