MBP 17" will not wake up from sleep
Closed the lid one evening. Opened it next morning and nothing happened. And whatever I try, nothing has happened since!
When I open the lid, the front LED is on (solid, not breathing), the fans run (quietly) and the hard drive runs (but I don't hear the heads moving).
I have removed the battery and power, left it for a day. No luck. Exactly the same. No chimes, no display, just LED, fans and (non-booting) disk.
I have used the tutorial here to remove the RAM battery as well.
Still the same.
I'm writing this question in the hope that there is another solution than a new logic board!
Any and all suggestions welcome.
Esta pergunta é pertinente?
1 dos comentários
Request for clarification: If you removed the battery and power, it is no longer sleeping. This is NOT a wake from sleep issue, your MBP fails to boot. Unfortunately you can not change a Question Title in ifixit.com, so I suggest a new question. Include the info about the failure to wake as background, but that is not the issue now.
One of my machines has failed to wake from sleep for years, but it still boots up fine every morning...
If this is not the case, please let me know.
por Dave
