Ir para o conteúdo principal
Pergunta encerrada
Won't Power On After Turned Around?
I was using it one day on my bed, and After I shifted it around to face me it shut off. I tried turning it back on and it didn't work- my battery doesn't hold a charge anymore so I have to keep it plugged in, so I figured I had twisted the charger and it broke, so I replaced it. Didn't fix the problem. So I figured it was the DC in Board , so I replaced that, but that didn't work either. What other part could it be if it isn't the charger or the DC in Board???
Thanks,
Portia
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Have you tried a different charger? The issue may not be with the iBook but the charger itself. If you know anyone else who has one I would give that a shot.
Also, if your computer isn't holding a charge anymore, I would recommend picking up a new battery.
Esta resposta foi útil?
Pontuação 0
2 comentários:
- Hey Andrew, did you read the question? He said in the first posting of the Q (no edits) " I figured I had twisted the charger and it broke, so I replaced it." So he has replaced the charger.
por
I apologize, I misunderstood the question.
por
First thing to try is resetting the power management chip.
Apple says: "The Power Manager is an integrated circuit (computer chip)...on the logic board of the PowerBook and iBook"
Unplug power, remove the battery, hold the power button down for 10 seconds.
Put the battery back in, plug in to power, turn on (single press of the power switch).
If that fails, onward!
There is a chance that the battery is helping to cause the problem. Any chance you could borrow another battery to try?
Replacing the battery, or, even better, having it "re-celled". I can not find the link at the moment, I had one for a place which recells Mac batteries...
Try press & hold <control><command><power>
Release, wait several seconds, press power.
http://support.apple.com/kb/TA25686
There are some reports of this working, probably for a different model
Try <control><shift><power>
http://en.kioskea.net/forum/affich-31408...
Also - Press & hold power by itself for several seconds (that is force-power-off command, so I doubt it will turn power on).
You can not reset the PRAM without turning on the machine, so PRAM should not be able to prevent power-on!
Anyone care to start a guide for recelling (not reselling!) Mac batteries?
I am tempted to suggest the Genius Bar...
Make sure you tell them about everything you have replaced if you do take it in.
I thought I could add more to this, but I got nuthin' now...
Pontuação 0
1 comentário:
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,127
