Is there a way to check the proximity sensor without calling
is there a way to check the proximity sensor without calling for the iphone 5/5s/ and 5c?
Esta é uma boa pergunta?
Yes. Use iPhone stock apple app Voice Memos. Make short recording, play back with loud speaker OFF, and then you can test the Proximity Sensor.
Esta resposta foi útil?
Works perfectly! The test was a succes, my Proximity sensor works fine, but still the problem while calling.
woooow.. thank you berry berry much.. :) it worked like a charm :) .. I see my proximity sensor works fine but if I place my hand near earpiece speaker but too close to the screen. I mean with very close distance.. may be a few milimeters from sensor screen turns on again..
hi, if its possible can you please elaborate a little about "loud speaker OFF" and whether the proximity test is by placing a hand/finger on top of the phone or other method?
thanks in advance :)
How do we do this in iOS 12, now that the lousdpeaker is the only playback device for voice memos? (Client did not leave SIM in phone)
TIA
You can use Phone diagnostics app developped by Hitek Nova to test most of the functions including proximity sensor:
I tried this app. It's helpful to test LCD, touch panel. It also can test camera, buttons & touch ID of the device. Great!
My wife uses Samsung and when she finds the similar app on Google Play, she saw Phone Doctor Pro with the same UI. Not sure they're from the same developer or not...
If you have raise to talk for siri enabled, that might work.
Hey Siri this is Farzana here
Hi farzana, what can I do for you
yea i think so may b not tho idk really sory
You can use voice record to test proximity
Not in iOS 12.
On an iPhone 8, IOS 12.1.4, during call screen goes black after i bring it close to the ear.
During or after call, once I take the phone from the ear, either to see who is calling or to check anything or to close the connection after ending the call, screen remains black.
I need to hit the home button to activate the screen again. O i need to wait a lot to get the screen active again.
It looks the sensor is responding in one way but not in the opposite way.
Please advice. Thanks
Same here on iphone 8 and same software.
It only happens with calls. (I tested the sensor with the voice memo app and it worked perfectly.)
I tried doing this with my iphone 7 plus but I don't have the option to turn off speaker phone.... so how do I turn off speaker phone to check the prox
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 38
Duração total: 95,846
